BT.com
Wishlist
Linksys X1000 Dual-WAN ADSL 2/2+ Wireless-N Router (300Mbps)
Linksys X1000 Dual-WAN ADSL 2/2+...
Last Few Remaining
£34.99
Last Few Remaining
Price Drop
Price Drop!
£34.99
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Built-in DSL modem
Directly connects you to the internet wirelessly -- no separate DSL modem required. The Linksys X1000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
Fast wireless speed
The Linksys X1000 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates of up to 300 Mbps.
Reliable wireless coverage
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home*.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Cisco Connect Express
Control your network with ease from your android or iOS mobile device with the Cisco Connect Express app, including adding devices and giving guests access.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customise settings or quickly add new devices to your network. Cisco Connect enables you to:
Create a separate, password protected network for guests
Limit access time and access to certain websites with parental controls
Access advanced network settings easily
Measure your connection speed with the Broadband Speed Meter
Perform regular automated update checks for firmware and software with the option to install
Linksys X1000 - wireless router - DSL modem - 802.11b/g/n - desktop, wall-mountable
Wireless router - DSL modem - 3-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Remote Management Protocol
TR-069
IPv6 support, MIMO technology, wall mountable, Wi-Fi Protected Setup (WPS), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
18 cm x 16.7 cm x 3.43 cm
285 g
United Kingdom
2 years warranty
Wireless router - 3-port switch (integrated)
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
TR-069
Encryption Algorithm
WPA, WPA2
Status Indicators
Power, WAN, LAN, wireless
Communications
DSL modem
ADSL, ADSL2, ADSL2+
WAN: 1 x ADSL2+ - RJ-11 , LAN: 3 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
1 x phone cable , 1 x network cable
United Kingdom
Software Included
Drivers & Utilities
18 cm
16.7 cm
3.43 cm
285 g
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.61
£50.74
Scroll to top
