Click to visit BT.com
BT.com
Wishlist
Linksys Wireless-N Router
Quicklinx: 8LJRWS00
Mfr#: E1200-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11n
Speed: 300Mbps
Rackmount or External: External
£21.98
Best for:
Standard-sized homes, flats, and halls of residence, surfing the Web, emailing and printing wirelessly, and connecting multiple devices
Features:
Wireless-N (2.4 GHz)
Fast Ethernet 4-port switch
High speed up to 300 Mbps
Fast wireless speed
The Linksys E1200 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates of up to 300 Mbps.
Reliable wireless coverage
MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network. Cisco Connect enables you to:
Create a separate, password protected network for guests
Limit access time and access to certain websites with parental controls
Access advanced network settings easily
Measure your connection speed with the Broadband Speed Meter
Perform regular automated update checks for firmware and software with the option to install
Linksys E1200 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP, HTTPS
Firewall protection, DMZ port, MAC address filtering, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
18.9 cm x 15.2 cm x 3.1 cm
253 g
United Kingdom
1 year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP , UL, cUL, ICES-003, RSS-210, FCC
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
18.9 cm
15.2 cm
3.1 cm
253 g
1 year warranty
Service & Support Details
Limited warranty - 1 year
10 - 80% (non-condensing)
Linksys Wireless-N Router Bundle deal on Linksys Wireless-N Router
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£31.97
8LJR C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £5.97
8LJR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.17
8LJR C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.40
8LJR C2G 2m Cat6a Shielded Patch - Blue In Stock £8.92
8LJR C2G TruLink Media Gateway RJ45 Cap In Stock £0.70
8LJR C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £56.50
Speed: 300Mbps
Brand: Linksys
Price Range Inc VAT: 0 - 50
