BT.com
Wishlist
Linksys Wi-Fi Range Extender RE6300 DB AC750
Linksys Wi-Fi Range Extender RE6300...
£57.22
£57.22
Add to wishlist
Delivery
Standard Due date unavailable
Eliminate dead zones and boost the Wi-Fi signal from your existing router with the Linksys AC1200 BOOST EX Wi-Fi Range Extender (RE6400). The range extender features simple setup options which allow you to quickly determine optimal placement in relation to your router. It works with all Wi-Fi routers, including those from service providers, to deliver uninterrupted video and music streaming, smooth online gaming, and seamless content sharing.
This dual-band extender delivers AC1200 data transfer speeds (N300 + AC867 Mbps) for fast, uninterrupted Wi-Fi that you can enjoy in the far reaches of your home - even outdoors.
Linksys RE6300 - Wi-Fi range extender
External
United Kingdom
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
8.7 cm x 12.1 cm x 6 cm
1 year warranty
8.7 cm
12.1 cm
6 cm
United Kingdom
External
Wireless
IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Protected Setup (WPS), Cross-Band Technology, Spot Finder Technology, beamforming technology
Encryption Algorithm
WPA, WPA2, 128-bit AES
IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 1000Base-T - RJ-45
Limited warranty - 1 year , Technical support - 90 days
Other bundles
£57.22
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£60.70
Accessories
£4.95
£3.84
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.42
£52.93
Scroll to top
