BT.com
Wishlist
Linksys WAP300N Wireless Access Point N300 Dual Band
Linksys WAP300N Wireless Access...
£41.26
More than 50 in stock
£41.26
Add to wishlist
Delivery
Standard 3-5 working days
The Linksys WAP300N is a 4-in-1 device which functions as an access point, access point client, bridge or as a range extender. With Wireless-N technology and selectable dual band of 2.4 GHz and 5 GHz you will be able to gain more speed and range while minimizing any interference. Equipped with the detachable antennas, built in DHCP server and IPv6 support, you will be guaranteed the latest in technology
Wireless Convenience
Now you can grow your network by adding computers, printers and other wireless devices, without stringing cables. Reliable connectivity allows you to move your laptops, or set up your devices all around your home or office.
Easy Configuration
Push-button setup helps make it simple to add devices to your new wireless network. With Wi-Fi Protected Setup™, you just push a button on the Access Point and on your other device to automatically create the wireless connection. Device and security configuration is a snap with the browser-based configuration utility.
Secure Wireless
Advanced security features such as WPA2, WEP and Wireless MAC Filtering.
4-in-1 Device
Customize your wireless network expansion with 3 additional modes:
Bridge: Wirelessly join multiple networks together**
Media Connector: Connect wired devices to a wireless network
Range Extender: Increase existing wireless coverage
High Speed Connection
Connect at speeds up to 300Mbps for Fast transfer rates*.
Features:*
Create a new wireless network in hard to reach areas
Upgrade your network to Wireless-N
4-1 product to customize your wireless expansion
Experience faster video streaming and sharing
Linksys Wireless Access Point N300 Dual Band WAP300N - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Microsoft Windows 7, Microsoft Windows XP SP3 or later, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.8 or later
18.87 cm x 15.17 cm x 3.12 cm
207 g
2 years warranty
Radio access point
18.87 cm
15.17 cm
3.12 cm
207 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Port status, power, WPS
MAC address filtering, IPv6 support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), wireless bridge mode, reset button, Wireless Client Mode
Encryption Algorithm
WPA, WPA2, WEP
IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45 , 2 x aerial
1 x network cable
UL, cUL, ICES-003, RSS-210, FCC
External power adapter
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
10 - 80% (non-condensing)
Accessories
£4.95
£3.76
£11.54
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.26
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£51.78
Scroll to top
