BT.com
Wishlist
Linksys SE4008 8-Port Gigabit Switch
Linksys SE4008 8-Port Gigabit...
£34.90
6 in stock
£34.90
Add to wishlist
Delivery
Standard 3-5 working days
Introducing the latest member of the WRT family of home networking products: the SE4008 8-Port Gigabit Switch. While compatible with other routers, the SE4008 is a perfect companion to the WRT1900AC router. With sleek lines and designed to physically stack below the WRT1900AC router, the 8-Port Gigabit Switch expands your network while streamlining your WRT system.
Offering easy connectivity of up to eight devices, the new WRT Switch brings maximum Gigabit transfer speeds to your wired products. Its eight auto-sensing ports, along with Quality of Service (QoS) traffic prioritization, ensure optimal gaming, large-file downloading, HD streaming, and much more. The efficient ports will also disable and enter into power-saving mode when the WRT Switch detects a connected device is off or not in use, saving you both power and money.
It delivers Performance Perfected.™
Space-Saving Design: Build up your WRT system while saving desktop space with the Switch's unique stackable design
8 Gigabit Ports: 10x faster transfer speeds than Fast Ethernet
Quality of Service (QoS): Prioritize network traffic such as video and audio applications for optimal streaming from a connected router
Auto-Sensing Ports: Advanced ports maximize data flow rates to connected devices. Additionally, when a connected device is turned off or not in use, the SE4008 will place the port in power-saving mode
Easy Setup: Simply plug a router into the switch and instantly connect devices to your Wi-Fi® network
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
