BT.com
Wishlist
Linksys RE4100W-UK Universal N600 Dual Band Range Extender
Linksys RE4100W-UK Universal N600...
£38.73
7 in stock
£38.73
Add to wishlist
Delivery
Standard 3-5 working days
The Linksys RE4100W Wall-Plug Simultaneous Dual-Band WiFi Range Extender allows you to easily boost the range of your existing wireless router and create a strong, reliable Wi-Fi signal for laptops and smartphones in your home. This Linksys RE4100W Wi-Fi Range Extender delivers a coverage area of up to 7,500 square feet by repeating and redistributing the signal from the router to eliminate dead zones. This Linksys RE4100W Wi-Fi Range Extender is universally compatible with all Internet routers.
Eliminate dead spots and increase existing wireless coverage
Easily boost the range of your existing wireless router and create a strong, reliable Wi-Fi signal for all the connected devices in and around your home with this Linksys RE4100W Wi-Fi Range Extender. This Linksys RE4100W Wi-Fi Range Extender delivers an increased wireless coverage area of up to 7,500 square feet by repeating and redistributing the signal from the router. This allows you to enjoy fast Wi-Fi speeds on your laptop or tablet - even if you're outside on the patio or in the backyard.
Works with any Wi-Fi router or gateway
This Linksys RE4100W Wi-Fi Range Extender is universally compatible with all Internet routers, including your service provider's router. Just connect it to your network and you can access the Internet from any device, wherever you are in your home.
Dual wireless bands for maximum performance
Thanks to dual bands (2.4 GHz and 5 GHz), this Linksys RE4100W Wi-Fi Range Extender can deliver data transfer speeds of up to N300 Mbps + N300 Mbps so you can stream videos and play online games without interference.
New innovative crossband technology
With Crossband technology, the Dual Wireless bands can now receive information on one band and transmit on the other, reducing dropped data packets and creating a stronger, more consistent signal throughout your home.
Extend your Wi-Fi range up to 7,500 feet
Using this Linksys RE4100W Wi-Fi Range Extender, you can enjoy a Wi-Fi coverage area in your home of up to 7,500 square feet. The result is a stronger, more reliable Wi-Fi signal, allowing you to stay connected on your laptop or mobile device from anywhere inside - or even outside - your home.
Ethernet ports for wired connections
Along with wireless connectivity, we equipped this Linksys RE4100W Wi-Fi Range Extender with two Fast Ethernet ports so you can create reliable wired connections to desktop and laptop computers and other Internet-ready devices.
Quick and easy installation setup
Connect the power cable. Plug in the range extender midway between your router and the area without Wi-Fi. Wait for a solid light on the cover of the range extender. Then, on a computer, phone, or tablet, connect to the Wi-Fi network "Linksys Extender Setup." Set up using the web browser.
Minimum system requirements
For range extender setup, this Linksys RE4100W Wi-Fi Range Extender requires a wireless router or access point, along with a Wi-Fi-enabled computer that has an Ethernet port and that runs the Microsoft Windows XP SP3, Windows Vista SP1 or later, Windows 7, or Windows 8 operating system or the Mac OS X Leopard 10.5.8 or later, Snow Leopard 10.6.1 or later, Lion 10.7 or later, or Mountain Lion 10.8 or later operating system.
Linksys RE4100W - Wi-Fi range extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Microsoft Windows 7, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.8 or later, Apple MacOS X 10.9, Apple MacOS X 10.10
1 year warranty
United Kingdom
External
Wireless
Data Transfer Rate
600 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, link/activity, WPS
Wall mountable, Wi-Fi Protected Setup (WPS), reset button, Apple AirPlay, Cross-Band Technology
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Aerial
Antenna
Internal
Antenna Qty
2
1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack
Software Included
Drivers & Utilities
Limited warranty - 1 year
Scroll to top
