BT.com
Wishlist
Linksys N750 Dual-Band Wireless Router with ADSL2+ Modem and USB
Linksys N750 Dual-Band Wireless...
£99.94
19 in stock
£99.94
Add to wishlist
Delivery
Standard 1-3 working days
Built-in DSL Modem - Directly connects you to the internet wirelessly -- no separate DSL modem required. The Linksys X3500 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
The Linksys X3500 offers fast speed to connect your computers, Internet-ready TVs, game consoles and other WiFi devices at transfer rates up to 300 + 450 Mbps for an optimal home network experience.
Reliable Wireless Coverage - The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced Security - Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
The Power of Dual-Band - Double your network bandwidth with Dual-Band N (2.4 and 5 GHz) designed to avoid interference and maximise throughput. Ideal for HD video streaming, high speed file transfers and wireless gaming.
Beneflfits of Gigabit - Use the four Gigabit Ethernet ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices like computers, hard drives, and servers.
Built-in USB port and DLNA Certified® media server - The USB port let you add storage devices and printers to your network to share files or print wirelessly throughout your home. The built-in DLNA Certiflfied® media server enables media streaming to your TV, Xbox 360, PS3, or other DLNA compatible devices.
Header / Packaged Quantity
1
Miscellaneous / Encryption Algorithm
104-bit WEP, 128-bit WEP, 40-bit WEP, 64-bit WEP, WPA, WPA-Enterprise, WPA2, WPA2-Enterprise
Networking / WAN Ports Qty
2
Service & Support / Type
2 years warranty
Dimensions & Weight / Depth
20 cm
Dimensions & Weight / Width
21.5 cm
Dimensions & Weight / Height
4 cm
Dimensions & Weight / Weight
451 g
Networking / Integrated Switch
4-port switch
Networking / Wireless Protocol
802.11 a/b/g/n
Modem / Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Networking / Form Factor (FE)
Desktop, Wall-mountable
Networking / Network / Transport Protocol
DHCP, L2TP, PPPoE, PPTP
Standards
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Modem / Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
Header / Manufacturer
Linksys
Header / Product Line
Linksys
Header / Model
N750 Dual-Band Wireless Router with ADSL2+ Modem and USB (X3500)
Header / Compatibility
PC
Networking / Routing Protocol
Static IP routing
Header / Country Kits
United Kingdom
Networking / Connectivity Technology
Wired, Wireless
Wireless router
Other bundles
Linksys N750 Dual-Band Wireless Router with ADSL2+...
£99.94
Save on TP Link Smart Plug
Save £2.00
£123.91
Scroll to top
