BT.com
Wishlist
Linksys LGS124P-UK Unmanaged 24-Port PoE Switch
Linksys LGS124P-UK Unmanaged...
£221.60
15 in stock
£221.60
Add to wishlist
Delivery
Standard 1-3 working days
Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed. Power over Ethernet (PoE) capability also carries electrical power to peripheral devices without the need for additional outlets.
Linksys LGS124P - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Bandwidth: 48 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
AC 100/230 V (50/60 Hz)
44 cm x 20 cm x 4.4 cm
2.785 kg
United Kingdom
Bundled Services
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
Bandwidth: 48 Gbps
8000 entries
Status Indicators
Port transmission speed, PoE, link/activity
12 x 1000Base-T - RJ-45 - PoE+ , 12 x 1000Base-T - RJ-45
Internal power supply
17.65 Watt
Plug and Play, FCC Class A certified, UL, CB
United Kingdom
44 cm
20 cm
4.4 cm
2.785 kg
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
