BT.com
Wishlist
Linksys LGS116P-UK Unmanaged 16-Port PoE Switch
Linksys LGS116P-UK Unmanaged...
£137.52
More than 50 in stock
£137.52
Add to wishlist
Delivery
Standard 1-3 working days
The unmanaged switch offers gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
PoE support lets you deploy network systems such as wireless access, IP telephony, or video surveillance solutions more quickly and at a lower cost, without having to install separate power supplies for individual devices.
Linksys LGS116P - switch - 16 ports - unmanaged - desktop, wall-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 8 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
80 W
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
AC 100/230 V ( 50/60 Hz )
28 cm x 12 cm x 2.5 cm
822 g
United Kingdom
Bundled Services
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
80 W
Performance
Bandwidth: 32 Gbps
8000 entries
Status Indicators
Port transmission speed, PoE, link/activity
8 x 1000Base-T - RJ-45 - PoE+ , 8 x 1000Base-T - RJ-45
External power adapter
11.31 Watt
Plug and Play, FCC Class A certified
United Kingdom
28 cm
12 cm
2.5 cm
822 g
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
