BT.com
Wishlist
Linksys LGS116-UK Unmanaged 16-Port Switch
Linksys LGS116-UK Unmanaged 16-Port...
£109.00
£109.00
Add to wishlist
Delivery
Standard 1-3 working days
Upgrade the data transfer speeds of your local wired network to information superhighways with the Linksys LGS116 16-Port Desktop Gigabit Switch.
This Linksys LGS116 16-Port Switch allows you to accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed. Furthermore, the Linksys LGS116 switch is simple to set up offering a quick and easy solution to extend your office network.
Gigabit Performance
This Linksys LGS116 16-Port Desktop Gigabit Switch offers Gigabit speeds to minimise transfer times and greatly enhance the ability to stream high bandwidth files to connected devices without interference.
Quality of Service (QoS) traffic prioritisation
QoS traffic prioritisation provides the ability to give precedence to particular devices or activities to ensure mission critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimise speed for each connected device.
Sixteen (16) 10/100/1000 Gigabit Ethernet ports.
Quality of Service (QoS) traffic prioritisation.
Easy plug and play connection for simple set-up.
Fanless design ensures quiet operation.
Wall mountable for convenient deployment.
Power saving features: Cable connected detection and sleep mode.
Supporting standards: IEEE 802.3, 802.3u, 802.3x, 802.3ab, 802.3az.
Strong robust metal enclosure design.
Standard warranty: limited lifetime
Linksys LGS116 - switch - 16 ports - unmanaged - desktop, wall-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
8000 entries
Auto-sensing per device, Quality of Service (QoS), fanless, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 100/230 V ( 50/60 Hz )
28 cm x 12 cm x 2.5 cm
774 g
United Kingdom
Bundled Services
Enclosure Type
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Bandwidth: 32 Gbps
8000 entries
Status Indicators
Port transmission speed, link/activity
16 x 1000Base-T - RJ-45
External power adapter
9.32 Watt
Plug and Play, FCC Class A certified
United Kingdom
28 cm
12 cm
2.5 cm
774 g
Limited warranty - lifetime
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
