BT.com
Wishlist
Linksys LGS105-UK Unmanaged 5-Port switch
Delivery
Standard 3-5 working days
Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
The unmanaged switch offers Gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
The Linksys unmanaged switch offers a quick and easy solution to extend your office network with plug & play installation.
Power saving features include auto power-down to disable unused ports, smart power for short cable runs, and a port status switch to control LED lights.
Header / Manufacturer
Linksys
Header / Model
LGS105
Networking / Type
Switch
Networking / Form Factor
Desktop
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Ports
5
Header / Packaged Quantity
1
Miscellaneous / Product Colour
Blue
POE
No
Managed
No
Header / Compatibility
PC
Header / Country Kits
United Kingdom
Dimensions & Weight / Height
2.6 cm
Dimensions & Weight / Width
12.1 cm
Dimensions & Weight / Depth
7.5 cm
Service & Support / Type
Accessories
£4.95
£3.82
£11.91
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.50
£54.00
Scroll to top
