BT.com
Wishlist
Linksys LCAD03FLN-UK SMB grade Indoor Dome 3M PoE Camera
Linksys LCAD03FLN-UK SMB grade...
£302.16
£302.16
Add to wishlist
Delivery
Standard Due date unavailable
Protect your business and enhance your situational awareness with the Linksys 1080p 3-magepixel indoor night vision dome camera. Whether you're outfitting an office, warehouse, store, or restaurant, Linksys network cameras provide superior security, surveillance, and supervision.
Linksys 1080p 3MP Indoor Night Vision Dome Camera - network surveillance camera
Network surveillance camera - fixed dome
Audio
Yes: two-way audio capability
Camera Mount Type
Ceiling mount
0.58 kg
Wired
Camera
Colour - Day&Night
Max Resolution
2048 x 1536
Optical Sensor Type
CMOS
Minimum Illumination
0.5 lux - colour - F1.6 , 0 lux - B&W - F1.6
Focal Length Control
Fixed focal
Focal Length
4 mm - 4 mm
Lens Iris
Fixed iris
Ethernet 10Base-T/100Base-TX
Voltage
PoE
Power over Ethernet, Wide Dynamic Range (WDR), Motion Detection Technology, Privacy Mask Function, ePTZ, multi-streaming, Audio Detect, SD/SDHC-card slot
Environmental Parameters (operating)
0 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
Audio Support
Camera Mount Type
Ceiling mount
Wired
0.58 kg
United Kingdom
Camera
Colour - Day&Night - fixed dome
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Video Capture
2048 x 1536 @ 18 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
CMOS
Lens Construction
Fixed focal
Focal Length
4 mm - 4 mm
Lens Iris
Fixed iris
Horizontal Field of View (degree)
62 - 62
Vertical Field of View (degree)
34 - 34
Network Interface
1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
FCC Class A certified, IC Class A, IP67, IK10
Power Requirements
PoE
50 °C
Relative Humidity (operating)
Other bundles
Linksys LCAD03FLN-UK SMB grade Indoor Dome 3M PoE...
£302.16
Save on TP Link Smart Plug
Save £2.00
£326.13
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
