BT.com
Wishlist
Linksys High Gain Antenna Kit - 4 Pack
Linksys High Gain Antenna Kit - 4...
£60.81
28 in stock
£60.81
Add to wishlist
Delivery
Standard 3-5 working days
Linksys dual-band, omni-directional high-gain antennas increase the range of your wireless router, providing enhanced coverage in a horizontal plane. They are latest in the Linksys line of premium products, with each antenna delivering 4dBi in the 2.4GHz band and 7dBi in the 5 GHz band - for up to 2x antenna gain over stock antennas. Easy to install, Linksys high-gain antennas are compatible with any wireless router featuring an RP-SMA connection. Simply detach router's factory antennas and replace with high-gain antennas. These come in two- and four-packs.
Linksys WRT004ANT - antenna
Antenna
Packaged Quantity
4 (specifications are for single item)
2.6 cm 1 cm
Length
28.8 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Surface mountable, indoor
Compatibility
802.11 b/g/n
Frequency Range
2.4 GHz, 5 GHz
Gain
7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
Directivity
Omni-directional
Packaged Quantity
Antenna
2.6 cm
1 cm
Length
28.8 cm
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g/n
Frequency Range
2.4 GHz, 5 GHz
Gain
Directivity
Omni-directional
Horizontal Beamwidth
360°
Vertical Beamwidth
30°
Cabling & Wiring
Connector Provided
1 x RP-SMA
Scroll to top
