BT.com
Wishlist
Linksys High Gain Antenna Kit - 2 Pack
Linksys High Gain Antenna Kit - 2...
£37.48
18 in stock
£37.48
Add to wishlist
Delivery
Standard 3-5 working days
High-gain wireless antennas offer an easy way to expand your wireless network's coverage. These antennas are equipped with omni-directional broadcast technology, which amplifies the signal strength of your Wi-Fi devices to deliver more wireless range and performance across the horizontal plane. This makes them ideal for large, single-story households that need a strong Wi-Fi signal.
Featuring Dual-Band support, these high-gain antennas can increase the signal to multiple devices connected to your network. Each of the high-gain antennas delivers up to 4 dBi on the 2.4 GHz band and up to 7 dBi on the 5 GHz band, offering up to 2x the antenna gain over stock antennas.
Compatible with any wireless device that uses a RP-SMA connection, these premium antennas are easy to use and install. Simply detach your router or Wi-Fi device's stock antennas and screw antennas into place - you'll immediately enjoy wider coverage throughout your home or office.
Linksys WRT002ANT - antenna
Antenna
Packaged Quantity
2 (specifications are for single item)
2.6 cm 1 cm
Length
28.8 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Surface mountable, indoor
Compatibility
802.11 b/g/n
Frequency Range
2.4 GHz, 5 GHz
Gain
7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
Directivity
Omni-directional
Packaged Quantity
Antenna
2.6 cm
1 cm
Length
28.8 cm
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g/n
Frequency Range
2.4 GHz, 5 GHz
Gain
Directivity
Omni-directional
Horizontal Beamwidth
360°
Vertical Beamwidth
30°
Cabling & Wiring
Connector Provided
1 x RP-SMA
Scroll to top
