BT.com
Wishlist
Linksys EA6700 Smart Wi-Fi Router Dual Band N450+AC1300 HD Video Pro
Linksys EA6700 Smart Wi-Fi Router...
£140.76
£140.76
Add to wishlist
Delivery
Standard Due date unavailable
Next Generation Wireless Technology:
Upgrade to the latest wireless-AC technology and enjoy a best-in-class HD video streamingexperience. Wireless AC technology provides gigabit Wi-Fi speeds and high-powered signalamplifiers, allowing content to download faster and large video or music files to sync more quicklyand stream seamlessly.
Wireless AC
Built with the latest Draft 802.11ac wireless technology for the leading performance and range.
Broad Compatibility
Works seamlessly with all a/b/g/n devices
Simultaneous Dual-Band 2.4 + 5GHz
Double the network bandwidth to avoid interference and maximize throughput
Ultimate Speed, Up to N450 + AC1300
Experience speeds approximately 3x faster than Wireless-N
Gigabit Ethernet ports
Four 10/100/1000 ports to connect wired devices at speeds 10X faster than Fast Ethernet
Easy setup
Simple installation, no CD required
SimpleTap™
Touch the SimpleTap card to an NFC-enabled device and easily connect it to your home network
Superior Range
High-powered signal amplifiers deliver ultimate range and performance
Two USB Ports 3.0 and 2.0
Allow you to share a variety of devices across your network, such as external hard drives and printers
Beamforming Technology
Focuses the wireless signal to reduce interference and improve speed and range
Advanced Security
Safeguard your network with WPA2 encryption and SPI firewall
Parental Controls
Easily manage access to content at home or while away with Smart Wi-Fi
Guest Network
Easily secure your network while providing guests with Wi-Fi access
Quality of Service (QoS)
Traffic prioritization technology delivers smooth performance for music, voice and video
IPv6 enabled
Supports the latest Internet Protocol technology to futureproof your network
DLNA CERTIFIED™
DLNA Media server enables media streaming your TV, Xbox, PS3, and other DLNA compatible devices
Wall Mountable
Flexible placement for convenience and optimal performance
Features:*
Dual Band N450 + AC1300*
Approximately 3x speed of Wireless-N
Smart Wi-Fi Apps, tools and mobility
Best-in-class HD video streaming
1 USB 3.0 port and 1 USB 2.0 port
4 Gigabit Ethernet ports
Linksys EA6700 - wireless router - 802.11a/b/g/n/ac - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Static IP routing
Stateful Packet Inspection (SPI), IPv6 support, parental control, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), SimpleTap technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5.8 or later, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8, Apple MacOS X 10.8 or later
United Kingdom
2 years warranty
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Static IP routing
Encryption Algorithm
WPA2
Status Indicators
Port status, power
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
1 x network cable
United Kingdom
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.42
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.05
£15.39
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£29.59
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.19
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
