Click to visit BT.com
BT.com
Wishlist
Linksys E900 Wireless-N Broadband Router (300Mbps)
Quicklinx: 8QZDWS00
Mfr#: E900-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: IEEE 802.11n
Speed: 300Mbps
Rackmount or External: External
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£17.44
E900 Wireless-N300 Router is built with leading 802.11n technology, create a powerful home wireless network in minutes. Connect your computers, Internet-ready TVs, game consoles, smartphones, and other Wi-Fi devices at fast transfer rates for an unrivaled experience.
Keep Wi-Fi freeloaders and Internet threats at bay with WPA2 encryption and SPI firewall to help keep your network protected.
Ideal for:
Surfing the web and emailing
Networking smaller homes or apartments
Connecting devices
Key features*:
High speed (up to 300 Mbps) for fast wireless transfer rates
Reliable range with MIMO antenna technology
Four Ethernet ports to connect wired devices to the network
Linksys E900 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
RIP, static IP routing
128-bit encryption, NAT support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, IPv4 support
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
18.9 cm x 15.2 cm x 3.1 cm
202 g
United Kingdom
1 year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Encryption Algorithm
128-bit WEP, WPA, WPA2
IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP , UL, cUL, ICES-003, RSS-210, FCC
Status Indicators
Link activity, power
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x RJ-45
Aerial
Aerial
Internal
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
18.9 cm
15.2 cm
3.1 cm
202 g
Limited warranty - 1 year
10 - 80% (non-condensing)
Linksys E900 Wireless-N Broadband Router (300Mbps) Bundle deal on Linksys E900 Wireless-N Broadband Router (300Mbps)
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£21.53
saving £1.39
8QZD C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £5.97
8QZD C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.91
8QZD C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.40
8QZD C2G 2m Cat6a Shielded Patch - Blue In Stock £8.96
8QZD C2G TruLink Media Gateway RJ45 Cap In Stock £0.70
8QZD C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £56.59
Speed: 300Mbps
Brand: Linksys
Price Range Inc VAT: 0 - 50
