BT.com
Wishlist
Linksys Dual Band AC1750 Access Point
Linksys Dual Band AC1750 Access...
£266.88
Hurry, only 1 left in stock!
£266.88
Add to wishlist
Delivery
Standard 1-3 working days
Linksys Pro Series wireless AC dual band access points deliver data rates at up to 3x faster than the 802.11n standard. With bandwidth speeds up to 1750 Mbps and wider 80 MHz channels your wireless network can grow without losing speed. Linksys Pro Series wireless-AC dual band access point implements a captive portal to support secure and customized guest Wi-Fi access and can be used at many Wi-Fi hotspots to control wireless access in the area.
Linksys Pro Series LAPAC1750PRO - radio access point
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
Power Over Ethernet (PoE) Supported
PoE+
23.8 cm x 24.7 cm x 4.33 cm
520 g
Radio access point
23.8 cm
24.7 cm
4.33 cm
520 g
United Kingdom
External
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
VLAN support, Syslog support, DiffServ support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, PoE+, wireless bridge mode, reset button, 3T3R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
1 x 1000Base-T (PoE+) - RJ-45
IC, FCC
PoE+
External power adapter
24 Watt
Limited warranty - lifetime
35 °C
10 - 85% (non-condensing)
Other bundles
£266.88
C2G 2m Cat5e Cable with Homeplug
Save £2.00
£270.36
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
