BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
LightwaveRF Wireless Control Quad Dimmer Light Switch (4Gang,2Way,210Watt) - Brass
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
See How LightwaveRF Can Transform Your Home Into a Smart Home!
LightwaveRF Dimmer switches look and operate the same way as standard high class light fittings. However, with the built in magic of LightwaveRF technology, the dimmers can now be wirelessly operated using any of the simple remote handsets from the LightwaveRF range; you can even use a Smartphone, Tablet or any other Web-enabled device to control your lights at or away from home with LightwaveRf WiFi Link (sold separately)* Each unit can act as a standalone or can be integrated with others into a personalised mood lighting setup in your living room. A mood takes just seconds to create and store, and it then can be recalled every time you enter the room at the touch of a button. The dimmers are suitable for one or two-way operation (slave unit required for two-way) and are installed in the same way as any standard light fitting using only a screwdriver. No extra wiring or cables are required and the dimmers fit into a standard 25/35mm back box. With LightwaveRF you can:Control your lighting, heating & power from your Smartphone, tablet or other web-enabled device, anywhere. Set heating and lighting routines that fit in seamlessly with your lifestyle. Monitor how much energy you're using.
Save money by reducing your energy bills. Control heating room-by-room via your Smartphone or other web-enabled device. Receive security alerts and live video direct to your phone. Set lights to switch on to appear at home when you're out or away. No re-wiring, no mess just a clean, simple installation process. LightwaveRF will transform the way you control your home's heating, lighting and power.
  • Remote controllable dimmer switch that operates the same as a standard one
  • Intelligent Lighting Control, Store and Recall `mood' lighting settings, Save Energy
  • Intuitive, easy to setup, use standalone or together with other LightwaveRF's Home Automation Devices
  • Control from anywhere using your Smartphone, Tablet or any other Web-enabled device with LightwaveRF's Wifi-Link* (sold separately)
  • *LightwaveRF App available from Apple, Android and Windows App Stores
Specification
  • Wireless Type - LightwaveRF: 433.92MHz
  • Power - Mains Power: 220 - 240V, 50Hz Maximum load: 210W (per gang)
  • Fitting - 2 Gang 25/35mm Back Box, 2-wire system (no neutral required)
  • Operation - 4 Gang Dimmer with 1 and 2-way operation (Slave Dimmer is also required for 2-way), On-Off, Dim Up-Down
Scroll to top
