BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
LightwaveRF Lighting 1 Gang 2-Way Dimmer - White
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Modern & sleek LightwaveRF White 1 Gang 2-Way Dimmer
  • 1 Gang 2 Way dimmer works exactly the same as a standard dimmer
  • The switches can be controlled by any LightwaveRF device
  • Simple to install uses existing wiring, set any type of mood in your home and save the settings so you can recall at your pleasure
  • This can be controlled by PC or smartphone when used with the WIFI link controller
  • 3V CR2032 lithium battery included
  • Surface mounted
  • Download LightwaverRF APP from your APP store
  • 88x88x30mm (HxWxD)
Scroll to top
