Click to visit BT.com
BT.com
Wishlist
LightwaveRF Hand Held Group Controller for up to 12 Lighting & Power Mood Scenes
Quicklinx: 8HD7WS00
Mfr#: JSJSLW104WH
See How LightwaveRF Can Transform Your Home Into a Smart Home!
The LightwaveRF Connect Mood Remote Control has the ability to switch on/off or dim up/down any number of LightwaveRF devices simultaneously including dimmers and sockets. It also offers a quick and easy way to store and recall mood lighting settings. An All Off' feature is also included which will turn off all paired devices at the touch of a button. LightwaveRF will transform the way you control your home.<br /> </p><ul><li>Switch (on/off) or dim (up/down) any number of LightwaveRF Lighting, Power and Heating devices</li><li>Turn your LightwaveRF Light Switches and Power Sockets 'All Off' at the touch of a button </li><li>Intelligent Lighting Control, Store and Recall mood' lighting settings, Save Energy
  • Intuitive, easy setup and use
  • Spec
    • Wireless Type - LightwaveRF: 433.92MHz
    • Power - Battery: 3V CR2023 Lithium (included)
    • Fitting - Battery operated non-wired device
    • Operation - On-Off, Dim Up-Down
