BT.com
Wishlist
Liebert PSI XR 3000VA 2700W 230V RACK/TOWER UPS
Liebert PSI XR 3000VA 2700W 230V...
£1,043.53
Hurry, only 3 left in stock!
£1,043.53
Add to wishlist
Delivery
Standard 1-3 working days
Liebert PSI-XR 3000VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI-XR allows the unit to be configured as a self-standing tower or to be rack-mounted within a 2U space. It is available in four capacities.
Liebert PSI-XR PS3000RT3-230XR - UPS - 2700 Watt - 3000 VA
UPS - rack-mountable / external
Rack Size
2U
46 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
6 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
5 min at full load
USB, serial
Tower stand
Microsoft Windows 2000 / NT, Microsoft Windows Vista / XP
44 cm x 70.05 cm x 8.8 cm
2 years warranty
Height (Rack Units)
2U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage Range
AC 165 - 300 V
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
Power Capacity
2700 Watt / 3000 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
660 Joules
Circuit Protection
Circuit breaker
Efficiency
96%
Power Factor (PF)
0.9
Lead Acid
Run Time (Up To)
5 min at full load , 13 min at half load
Recharge Time
5 hours
Switchover Time
4 ms
Maintenance free, sealed
Remote Management Interface
USB, serial
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x Liebert IntelliSlot
Tower stand
4 x power cable - external , Serial cable - external , USB cable - external
Rack Mounting Kit
Included
IEC 62040-1-1, EN 62040-2, ISTA
Software Included
Drivers & Utilities
0 - 90%
Sound Emission
40 dBA
44 cm
70.05 cm
8.8 cm
46 kg
Shipping Width
56 cm
Shipping Depth
82.1 cm
Shipping Height
22.8 cm
Shipping Weight
51 kg
Scroll to top
