BT.com
Wishlist
Liebert PSI XR 1500VA (1350W) 230V RACK/TOWER UPS
Liebert PSI XR 1500VA (1350W) 230V...
£426.45
£426.45
Add to wishlist
Delivery
Standard Due date unavailable
Liebert PSI-XR 1500VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI-XR allows the unit to be configured as a self-standing tower or to be rack-mounted within a 2U space. It is available in four capacities.
Liebert PSI-XR PS1500RT3 - UPS - 1350 Watt - 1500 VA
UPS - external
Rack Size
2U
28 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1350 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5 min at full load
Ethernet 10/100
Remote Management Protocol
SNMP
Microsoft Windows 2000 / XP, Apple MacOS X 10.2 or later
44 cm x 49.1 cm x 8.8 cm
2 years warranty
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage Range
AC 165 - 300 V
Frequency Provided
45 - 65 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 45 - 65 Hz
Power Capacity
1350 Watt / 1500 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 Joules
Circuit Protection
Circuit breaker
Lead Acid
Voltage Provided
12 V
Run Time (Up To)
5 min at full load
Recharge Time
5 hours
Remote Management Interface
Ethernet 10/100
SNMP
1 x management (USB) - 4 pin USB Type B , 2 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x LAN
Expansion Slots
Expansion Slot
2 x power cable - external , Serial cable - external - 1.8 m , USB cable - external - 1.8 m
Rack Mounting Kit
Included
Audible alarm
IEC 62040-2 class B, IEC 62040-1-1, RoHS, WEEE
Software Included
Drivers & Utilities
0 - 90%
Sound Emission
40 dBA
44 cm
49.1 cm
8.8 cm
28 kg
Shipping Width
56 cm
Shipping Depth
61.2 cm
Shipping Height
22.8 cm
Shipping Weight
32 kg
Scroll to top
