BT.com
Wishlist
Liebert PSI  3000VA 2700W 230V RACK/TOWER UPS
Liebert PSI 3000VA 2700W 230V...
£795.50
£795.50
Add to wishlist
Delivery
Standard 1-3 working days
Liebert PSI 3000VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI allows the UPS to be configured as a self-standing tower or to be rack-mounted within a 2U space. It provides reliable power protection for servers, critical nodes, network workstations, large network peripherals, network routers, bridges, and other electronic equipment.
Liebert PSI PS2200RT3-230 - UPS - 2700 Watt - 3000 VA
UPS - external
Rack Size
2U
37.2 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid 9 Ah
Battery Form Factor
Plug-in module
Batteries Qty
6
Run Time (Up To)
3 min at full load
RS-232, USB
Tower stand
44 cm x 65.7 cm x 8.8 cm
2 years warranty
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage Range
AC 165 - 300 V
Frequency Provided
45 - 65 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 45 - 65 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 Joules
Circuit Protection
Circuit breaker
Quantity
6
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
3 min at full load , 3 min at 90% load , 4 min at 80% load , 5 min at 70% load , 7 min at 60% load , 9 min at half load , 12 min at 40% load , 17 min at 30% load , 32 min at 20% load , 76 min at 10% load
Recharge Time
5 hours
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Tower stand
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
LED display, remote ON/OFF function, hot-swappable batteries
EN 61000-3-2, IEC 61000-3-2, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-6, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, IEC 62040-1-1, IEC 62040-2, RoHS, EN 62040-1-1, EN 62040-2
Software Included
Liebert MultiLink
0 - 90% (non-condensing)
Sound Emission
45 dBA
44 cm
65.7 cm
8.8 cm
37.2 kg
Shipping Width
56 cm
Shipping Depth
77.6 cm
Shipping Height
22.8 cm
Shipping Weight
41.5 kg
Scroll to top
