BT.com
Wishlist
Liebert Intellislot Web Card-LB
£193.58
11 in stock
£193.58
Add to wishlist
Delivery
Standard 1-3 working days
For enhanced UPS communications and control, the Liebert IntelliSlot IS-WEBCARD delivers SNMP and web-management communications capability to your Liebert GXT unit. This feature will provide flexibility in how you monitor and control your UPS over the network. The card is also easily configurable to work in a standard SNMP implementation and with Liebert's MultiLink unattended shutdown software.
Liebert Intellislot Web Card - remote management adapter
Remote management adapter
Plug-in module
Interface (Bus) Type
Liebert IntelliSlot
7.6 cm x 13.4 cm x 3.8 cm
200 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, RS-232
Data Transfer Rate
100 Mbps
Liebert GXT3-1000MT120, GXT3-1000RT120, GXT3-1000RT230, GXT3-1500RT120, GXT3-1500RT230, GXT3-2000RT120, GXT3-2000RT230, GXT3-3000RT120, GXT3-3000RT208, GXT3-3000RT230, GXT3-500RT120, GXT3-700RT120, GXT3-700RT230
Plug-in module
Liebert IntelliSlot
Wired
Cabling Type
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS
Status Indicators
Power, link OK
DHCP support, BOOTP support, E-mail alert, firmware upgradable, SMS alert
1 x 100Base-TX - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x Liebert IntelliSlot
Encryption Algorithm
SSL
1.75 Watt
7.6 cm
13.4 cm
3.8 cm
200 g
55 °C
10 - 90% (non-condensing)
Scroll to top
