BT.com
Wishlist
Liebert Emerson Liebert PSI 750VA 230V Rack/tower UPS
Liebert Emerson Liebert PSI 750VA...
Free delivery
£277.53
Free delivery
£277.53
Add to wishlist
Delivery
Standard 1-3 working days
Liebert PSI 750VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI allows the UPS to be configured as a self-standing tower or to be rack-mounted within a 2U space. It provides reliable power protection for servers, critical nodes, network workstations, large network peripherals, network routers, bridges, and other electronic equipment.
Liebert PSI PS750RT3-230 - UPS - 675 Watt - 750 VA
UPS - external
Rack Size
2U
15 kg
Input Voltage
AC 230 V
Power Capacity
675 Watt / 750 VA
Input Connectors
1 x power IEC 60320 C13
Output connectors
8 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
4 min
RS-232, USB
44 cm x 41.2 cm x 9 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Input Voltage
AC 230 V
Input Connectors
Power Capacity
675 Watt / 750 VA
Surge Suppression
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
4 min
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Rack Mounting Kit
Included
44 cm
41.2 cm
9 cm
15 kg
Scroll to top
