BT.com
Wishlist
LG Electronics UM68 34" 2560x1080 5ms HDMI Display Port IPS Monitor
LG Electronics UM68 34" 2560x1080...
£445.06
More than 50 in stock
£445.06
Add to wishlist
Delivery
Standard 1-3 working days
Perfect for multitasking and entertaining, the LG 21:9 UltraWide™ is always the right choice. A full range of 21:9 UltraWide™ monitors, both curved and flat, are available to meet your needs.
21:9 UltraWide™ QHD on IPS Display
"21:9 UltraWide™ QHD (3440*1440) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all."
The Beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
The Big Convergence of FreeSync & 21:9 UltraWide™
The whole new FreeSync era has come. On the 34-inch 21:9 UltraWide™ QHD, you can experience the next level of gaming without any tearing and stuttering.
Game Mode
"Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres."
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
Flawless Color Expression
You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy.
Advanced Tech Design
The newly designed ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort.
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
LG 34UM68-P - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
82.99 cm x 25.24 cm x 42.89 cm
8 kg
Plug and Play, DDC/CI
Display Type
Energy Class
Class B
58 kWh
40 W
Diagonal Size
34"
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Split screen, Picture Mode, Auto Resolution, 99% Adobe RGB colour gamut, On-screen Digital Controls, Mercury free, MaxxAudio, Black Stabilizer
82.99 cm x 25.24 cm x 42.89 cm - with stand
8 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Flat Panel Mount Interface
75 x 75 mm
AC 120/230 V
43 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6 kg
Scroll to top
