BT.com
Wishlist
LG Electronics UC88 34" 2560x1080 5ms HDMI Display Port Curved IPS Monitor
LG Electronics UC88 34" 2560x1080...
£734.68
£734.68
Add to wishlist
Delivery
Standard 1-3 working days
This 21:9 UltraWide QHD display offers visual comfort and ensures amazing viewing pleasure. There is no color shift or distortion of color at all. Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
LG 34UC88 - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
Curved Screen
Adaptive Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (On/Off); 5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
81.76 cm x 25.24 cm x 44.78 cm
8.3 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
79 kWh
54 W
Diagonal Size
34"
Curved Screen
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, 99% sRGB colour gamut, Flicker Safe, Reader Mode, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Color Weakness Mode, Dark Room mode, Mega DFC, USB 3.0 Quick Charge
81.76 cm x 25.24 cm x 44.78 cm - with stand
8.3 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , DisplayPort , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
Key lock
AC 120/230 V
65 Watt
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows
Dimensions & Weight Details
With stand - width: 81.76 cm - depth: 25.24 cm - height: 44.78 cm - weight: 8.3 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.2 kg
Scroll to top
