BT.com
Wishlist
LG Electronics MP58VQ 24" 1920x1080 5ms VGA DVI HDMI LED Monitor
LG Electronics MP58VQ 24" 1920x1080...
£141.49
More than 50 in stock
£141.49
Add to wishlist
Delivery
Standard 1-3 working days
This LG IPS monitor ensures and awesome picture quality that provides clear images and vivid colors from any angle for your viewing pleasure.
LG 24MP58VQ - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
55.05 cm x 18.68 cm x 41.9 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
36 kWh
25 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture in picture, HDCP, 72% (CIE 1976) colour gamut, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Color Weakness Mode, Mega DFC
55.05 cm x 18.68 cm x 41.9 cm - with stand
3.2 kg
VGA , HDMI , DVI-D , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
Key lock
26 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg , Without stand - width: 55.05 cm - depth: 8.55 cm - height: 33.21 cm - weight: 2.8 kg
ENERGY STAR Certified
Scroll to top
