BT.com
Wishlist
LG Electronics M38H 24" 1920x1080 5ms VGA HDMI LED Monitor
LG Electronics M38H 24" 1920x1080...
£112.92
More than 50 in stock
£112.92
Add to wishlist
Delivery
Standard 1-3 working days
This display features Flicker Safe and Reader Mode to help maximize visual comfort by protecting your eyes from harmful blue light and greatly reducing the flicker level.
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 24M38H-B - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
HDMI, VGA
55.62 cm x 18.67 cm x 41.51 cm
2.8 kg
Plug and Play, DDC/CI
Display Type
Energy Class
Class A
31 kWh
21 W
Diagonal Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture Mode, SUPER Energy Saving Technology, Auto Resolution, Dual Smart Solution, 4-screen split, Multilingual On Screen Display
55.62 cm x 18.67 cm x 41.51 cm - with stand
2.8 kg
VGA , HDMI , Headphones
Mechanical
Flat Panel Mount Interface
100 x 100 mm
AC 120/230 V
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.62 cm - depth: 18.67 cm - height: 41.51 cm - weight: 2.8 kg , Without stand - width: 55.62 cm - depth: 5.68 cm - height: 34.4 cm - weight: 2.6 kg
Scroll to top
