BT.com
Wishlist
LG Electronics LG Scanner Mouse - Wired - USB 2.0
Delivery
Standard Due date unavailable
World's 1st Scanner Mouse
There are countless moments in everyday life where you wish you had a scanner to hand - when children want to scan teaching material or articles from magazines, or when you have to type the details of a document. With the LG Scanner Mouse one drag is all it takes to complete your scanning. The Scanner Mouse also features remarkable editing power that converts text into a Microsoft Word or Excel document. You can also share in real-time through Twitter, Facebook etc. From now on enjoy easier, faster scanning with the LG Scanner Mouse.
Dabs.com Product Reviews: LG Scanner Mouse
Easy to Use:
With the Drag function the LG Scanner Mouse is so easy to use. You just drag it across the paper you want to scan and you can see the result on the screen immediately. Also a fully functioning 5 button laser mouse that you can use everyday.
OCR (Optical Character Recognition): The OCR function means that you no longer have to re-type text in order to edit it; just scan it with the LG Scanner Mouse and save it as an editable file, i.e. Microsoft Word.
Scanning of Multiple Sizes: You can scan any size up to an A3 or just scan a small area on a large sheet of paper.
Real-Time Scanning: You can send your scanned files as emails, SNS (via Facebook, Twitter etc) and via SmartPhones.
LG unveiling the world's first scanner mouse at CES 2011:
LG LSM-100 - mouse - USB
Mouse
Wired - USB
Movement Detection Technology
Laser
Buttons Qty
5
Movement Resolution
1200 dpi
OCR (Optical Character Recognition), Real-Time Sharing
Microsoft Windows Vista / XP / 7
Mouse
Input Device
Wired
USB
Laser
Buttons Qty
5
Movement Resolution
1200 dpi
1 x USB - 4 pin USB Type A
Scroll to top
