BT.com
Wishlist
LG Electronics LG E2411PU-BN - LCD display - TFT - WLED - 24" - widescreen - 1920 x 1080 - 250 cd/m2 - 1000:1
Delivery
Standard Due date unavailable
The E11 series offers excellent picture quality that can be realized by LED technology by showing sharper contrast of brightness and darkness. Whilst the energy-efficient technology reduces power consumption, compared to normal LCD (CCFL).
LG E2411PU-BN - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Pivot (rotation), tilt
Matte black
56.9 cm x 27.2 cm x 43.2 cm
5.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC/CI, TCO Displays 5.0
Display Type
Diagonal Size
24"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
H/V position
OSD-Digital Display Director, power off timer, f-ENGINE technology, HDCP, power on timer, Multiscan Support
Matte black
56.9 cm x 27.2 cm x 43.2 cm - with stand
5.1 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in , 2 x USB downstream , USB upstream (Type B)
Mechanical
Tilt Angle
25
Swivel Angle
355
Height Adjustment
110 mm
Backlight Life
50000 hours
30 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 27.2 cm - height: 43.2 cm - weight: 5.1 kg , Without stand - width: 56.9 cm - depth: 6.4 cm - height: 34.3 cm - weight: 3.7 kg
Accessories
£8.58
£9.51
£16.15
C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL
Quicklinx: 63SL | In Stock
£9.61
£9.48
C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1Y | In Stock
£46.48
C2G 2m HDMI to DVI-D Digital Video Cable
Quicklinx: 915T | In Stock
£8.61
£62.64
Scroll to top
