BT.com
Wishlist
LG Electronics LG 55LS75A 55" 1920x1080 8ms DVI HDMI LED Large Format Display
LG Electronics LG 55LS75A 55"...
£2,404.96
£2,404.96
Add to wishlist
Delivery
Standard Due date unavailable
The display switches signals from first player to second player as well as signals from an external player to internal memory in case of a player’s failure
LG’s advanced self-diagnosis function checks the screen status with an optional pixel sensor and supports the SNMP standards for compatibility with 3rd party solutions.
Compatible with open pluggable specification (OPS), users have the flexibility to choose the appropriate media player.
A Wi-Fi dongle can be connected to the LS75A for easy installation and simple management.
LG 55LS75A 55" Class (54.64" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
720p, 1080i, 1080p
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
Voltage
140 Watt
123 cm x 3.2 cm x 70.1 cm
20.7 kg
Environmental Standards
ENERGY STAR Qualified
140 Watt
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
123 cm
3.2 cm
70.1 cm
20.7 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
700 cd/m²
Response Time
8 ms
Backlight Life
50,000 hour(s)
Certified for 24/7 Continuous Operation, compatible with SuperSign Software
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
720p, 1080i, 1080p
Media Player
USB Port
Remote Control
Standard remote
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
Network , DisplayPort input , 2 x HDMI input , DVI-D input , Serial input , Audio line-in , Serial output , DisplayPort output , Speakers output
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Dimensions & Weight Details
Panel without stand - 123 cm x 3.2 cm x 70.1 cm x 20.7 kg , Panel with stand - 123 cm x 29.8 cm x 77.6 cm x 22.1 kg , Panel with stand and speakers - 123 cm x 29.8 cm x 77.6 cm x 22.9 kg
Width (Shipping)
133 cm
Depth (Shipping)
17.4 cm
Height (Shipping)
81 cm
Weight (Shipping)
25.2 kg
10 - 80%
Accessories
£7.23
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.25
£39.28
£52.56
£17.48
Scroll to top
