BT.com
Wishlist
LG Electronics 98LS95A 98" 3840x2160 DVI HDMI DP 4K LED LFD
Delivery
Standard Due date unavailable
Ultra HD Large screen delivers immersive viewing experience. Ultra HD delivers immersive viewing experience by 4 times higher definition picture quality than FHD. 98" real size displays deliver seamless contents so that could be alternative solution of 2x2 video wall at flagship store.
It works perfectly even if it is pulled by the gravity on portrait mode thanks to its advanced panel technology. The enhanced fail over function enables to display contents in internal memory without a dead spot even when the conditions of all external inputs are not working.
LG 98LS95A 98" Class (97.52" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
98"
Diagonal Size
97.52 in
Commercial Use
Yes - digital signage
Platform
webOS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Black level correction
Speaker System
2 speakers
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
USB
3 ports
Remote Control
Standard remote
Voltage
510 Watt
219.2 cm x 6.9 cm x 124.7 cm
88 kg
Environmental Standards
ENERGY STAR Qualified
510 Watt
Diagonal Class
98"
Diagonal Size
97.52 in
Commercial Use
Platform
webOS
TV Tuner
No tuner
Sensors
Temperature sensor, auto brightness sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
HDCP Compatible
Modes
Portrait mode, landscape mode, Picture mode
Dimensions
Without stand
219.2 cm
6.9 cm
124.7 cm
88 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Coating
Anti-reflection
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
8 ms
Colour Temperature Control
Yes (Warm/Medium/Cool)
Gamma correction, Dynamic Contrast, Digital Noise Reduction (DNR), digital daisy chain, Dynamic Color Enhancer, key lock, 4K Upscaling, Dynamic Clear White, Input Labelling, compatible with SuperSign Software, Enhanced Fail Over
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
800 x 400 mm
DVR
DVR
Flash - 8 GB
Media Player
Supported Video Formats
HEVC
USB Port
USB Ports Qty
3
PC Configuration
Dual Core / 1 GHz / 1.25 GB DDR3
8 GB
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance
Speaker System
2 speakers
Output Power / Total
20 Watt
On/off switch, Clear Voice II technology
Network & Internet Multimedia
Wi-Fi
Connector Type
2 x HDMI input , DVI-D input , DisplayPort input , DisplayPort output , Audio input , Serial input , Serial output , Network , Remote control/ambient sensor input , 2 x USB 2.0 , USB 3.0 , SPDIF output
IR receiver, Wi-Fi module
DisplayPort cable , HDMI cable , Serial cable , Audio adaptor
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
2 Watt
Power Consumption Sleep
0.5 Watt
Smart energy saving
Width (Shipping)
234.2 cm
Depth (Shipping)
40.2 cm
Height (Shipping)
138.9 cm
Weight (Shipping)
123 kg
10 - 80%
Accessories
£9.99
£5.41
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.68
£40.09
£54.31
Scroll to top
