BT.com
Wishlist
LG Electronics 84WT70 84" 3840x2160 HDMI USB LED Large Format Display
Delivery
Standard Due date unavailable
LG's touch technology provides smooth and accurate 10 point multi-touch interaction & gestures with precision for your interactive needs. When touching the screen, it is possible to express your writing or drawing with 'No Ghosting' for clean & seamless navigation.
LG 84WT70 84" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
2 ports
Remote Control
Standard remote
Voltage
350 Watt
195.1 cm x 11.2 cm x 113.7 cm
102.6 kg
350 Watt
Diagonal Class
84"
Commercial Use
Combined with
Touchscreen
TV Tuner
No tuner
Sensors
Temperature sensor, auto brightness sensor
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Landscape mode
Dimensions
Without stand
195.1 cm
11.2 cm
113.7 cm
102.6 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Touchpoints Qty
10
Response Time
12 ms
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Audio Controls
Balance
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
VGA input , 2 x HDMI input , 2 x USB 2.0 , Audio line-out , Network , Serial output , DVI-D input , Audio line-in , DisplayPort input , Composite video input , Serial input , DVI-D output , VGA output
FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC, ERP
Power supply
Nominal Voltage
Smart energy saving
Width (Shipping)
205 cm
Depth (Shipping)
33 cm
Height (Shipping)
126.1 cm
Weight (Shipping)
118 kg
10 - 80%
Scroll to top
