BT.com
Wishlist
LG Electronics 84WS70MS 84" 3840x2160 DVI HDMI 4K USB LED LFD
LG Electronics 84WS70MS 84"...
£7,051.76
21 in stock
£7,051.76
Add to wishlist
Delivery
Standard 1-3 working days
The sheer size of the screen, equal to four 42-inch class displays, gives you a breathtaking viewing experience. The picture is so big and immersive, it's as if you're in the scene and part of the action.
Boasting a pixel resolution 4x higher than Full HD (1080p), its detail is so vivid and crisp, even when viewed from a close distance.
LG 84WS70MS 84" LED display
LED-backlit LCD flat panel display
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Wall Components Qty
25
Video Interface
HDMI
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
AH-IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
Remote Control
Standard remote
Voltage
AC 120/230 V (47 - 63 Hz)
350 Watt
192.3 cm x 10.1 cm x 110.94 cm
72.9 kg
3 years warranty
350 Watt
Diagonal Class
84"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI
PC Interface
HDCP Compatible
25
Dimensions
Without stand
192.3 cm
10.1 cm
110.94 cm
72.9 kg
Display
LCD Display Technology
AH-IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.484 x 0.484mm
Response Time
12 ms
Media Player
Supported Video Formats
DivX
Supported Audio Formats
MP3
Supported Pictures Formats
JPG
USB Port
Remote Control
Standard remote
Connector Type
VGA input , Serial , HDMI input , USB , Network , DisplayPort input , DVI-D input
VGA cable
FCC Class B certified, UL, TUV, VCCI, C-Tick, KCC
Power supply
Nominal Voltage
Power Consumption Stand by
1 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years - pick-up and return
Accessories
£7.05
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.13
£37.29
£50.50
Scroll to top
