BT.com
Wishlist
LG Electronics 84WS70B 84" 3840x2160 4K LED Large Format Display
LG Electronics 84WS70B 84"...
£5,880.00
£5,880.00
Add to wishlist
Delivery
Standard Due date unavailable
LG 84WS70B are LED large screens which provides immersive wide viewing with high quality.
LG 84WS70B WS70 Series - 84" LED display
LED-backlit LCD flat panel display
Diagonal Class
84"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit, local dimming
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
USB
2 ports
Remote Control
Standard remote
Voltage
350 Watt
192.3 cm x 5.1 cm x 110.9 cm
72.9 kg
350 Watt
Diagonal Class
84"
Commercial Use
Series
WS70 Series
TV Tuner
No tuner
Sensors
Temperature sensor, auto brightness sensor
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Timer Functions
Sleep, wake
Dimensions
Without stand
192.3 cm
5.1 cm
110.9 cm
72.9 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Coating
Anti-glare
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
12 ms
Backlight Life
50,000 hour(s)
Commercial Features
Digital signage
Dynamic Contrast, Eye Care, Super Resolution Technology (SRT), MPEG Noise Reduction, Dynamic Color Enhancer, key lock, Dynamic Clear White, Input Labelling, compatible with SuperSign Software
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
VGA input , Serial input , 2 x HDMI input , 2 x USB , VGA output , Network , Serial output , DVI-D input , DVI-D output , Speakers output , DisplayPort input , Composite video input , Audio output , Audio input
VGA cable
FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
Auto On/Off
Smart energy saving
Width (Shipping)
203.4 cm
Depth (Shipping)
31.4 cm
Height (Shipping)
121.3 cm
Weight (Shipping)
87.2 kg
10 - 80%
Scroll to top
