BT.com
Wishlist
LG Electronics 65LS33A 65" 1920x1080 9ms HDMI RGB LED Large Format Display
LG Electronics 65LS33A 65"...
£2,465.60
£2,465.60
Add to wishlist
Delivery
Standard Due date unavailable
The panel featuring a direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency.
LG 65LS33A 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
720p, 1080i, 1080p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB Port
Yes , 1 ports
AC 120/230 V ( 50/60 Hz )
Energy Class
Class A
145 Watt
Power Consumption (On mode)
145 W
Energy Consumption per Year
212 kWh
146.2 cm x 5.8 cm x 84.3 cm
30.9 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class A
145 Watt
145 W
212 kWh
Diagonal Class
65"
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Modes
Portrait mode, landscape mode
Dimensions
Without stand
146.2 cm
5.8 cm
84.3 cm
30.9 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
1500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Image Sticking Minimization (ISM), key lock
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
720p, 1080i, 1080p
Supported Computer Resolutions
1920 x 1080
Media Player
USB Port
Yes , 1 ports
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Balance control, Clear Voice II technology
Network & Internet Multimedia
LAN
Connector Type
HDMI input , VGA input , Audio line-in , Serial input , Infrared (IrDA) , Network , USB , Audio line-out , Serial output
FCC Class A certified, UL, TUV, cUL, CB, EMC, KCC, KC, ERP
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 146.2 cm x 5.8 cm x 84.3 cm x 30.9 kg , Panel with stand - 146.2 cm x 31.3 cm x 90.1 cm x 32.3 kg , Panel with stand and speakers - 146.2 cm x 31.3 cm x 90.1 cm x 33.1 kg
Accessories
£7.69
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£22.29
£42.00
£57.43
Scroll to top
