BT.com
Wishlist
LG Electronics 55LS33A 55" 1920x1080 9ms HDMI RGB LED Large Format Display
Delivery
Standard Due date unavailable
The industry leading panel featuring a Direct-LED back light creates stylishly slim monitors designed to fit perfectly into narrow spaces in retail shops while ensuring high energy efficiency.
LG 55LS33A-5D 55" Class (54.64" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
Yes - digital signage
Titanium metallic
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
92 W
Energy Consumption per Year
135 kWh
124 cm x 5.6 cm x 71.7 cm
17.8 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
92 W
135 kWh
Diagonal Class
55"
Diagonal Size
54.64 in
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
124 cm
5.6 cm
71.7 cm
17.8 kg
Enclosure Colour
Titanium metallic
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
330 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Balance control, Clear Voice II technology
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
HDMI input - rear , VGA input - rear , Serial input - side , Network - rear , USB - side , Serial output - side , Speakers output - rear , Audio line-in - rear
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Smart energy saving
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel without stand - 124 cm x 5.6 cm x 71.7 cm x 17.8 kg , Panel with stand - 124 cm x 24.7 cm x 77 cm x 18.1 kg , Panel with stand and speakers - 124 cm x 24.7 cm x 77 cm x 18.9 kg
Width (Shipping)
133 cm
Depth (Shipping)
17.4 cm
Height (Shipping)
80.9 cm
Weight (Shipping)
22.3 kg
10 - 80%
Accessories
£7.05
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£20.13
£37.29
£50.50
Scroll to top
