BT.com
Wishlist
LG Electronics 55LF5610 55" Full HD LED TV
LG Electronics 55LF5610 55" Full HD...
£632.60
£632.60
Add to wishlist
Delivery
Standard Due date unavailable
Making TV Simple Again
55" LG LED TV WITH FREEVIEW
  • FULL HD RESOLUTION
  • FREEVIEW
  • IPS PANEL
  • METALLIC DESIGN
  • PLUG & PLAY
LG 55LF5610 55" LED TV
LED-backlit LCD TV
Diagonal Class
55"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
300 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T
Speaker System
2 speakers
Sound Effects
Virtual Surround Mode
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A+
Power Consumption (On mode)
75 W
Energy Consumption per Year
110 kWh
124.3 cm x 5.68 cm x 72.5 cm
17.3 kg
LED-backlit LCD TV
Energy Class
Class A+
75 W
110 kWh
Diagonal Class
55"
TV Tuner
Extended PVR
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Modes
Expert mode, ISF mode
Dimensions
Without stand
124.3 cm
5.68 cm
72.5 cm
17.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
H.264
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Surround Mode
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Optical Sound Sync, Wireless Sound Sync, Private Sound Sync
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
USB 2.0 , 2 x HDMI input , Digital audio output (optical) , SCART , Composite video / component video input , Audio line-in , Headphones
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Panel without stand - 124.3 cm x 5.68 cm x 72.5 cm x 17.3 kg , Panel with stand - 124.3 cm x 25.5 cm x 77.2 cm x 17.7 kg
Width (Shipping)
133 cm
Depth (Shipping)
17.4 cm
Height (Shipping)
81 cm
Weight (Shipping)
22.1 kg
Accessories
£632.60
Essential TV Accessory
£657.59
Other bundles
£632.60
Save when you buy Toshiba 1TB Portable Drive with this TV
Save £1.99
£678.59
Scroll to top
