BT.com
Wishlist
LG Electronics 49LF510V 49" WiFi Built In Full HD 1080p LED TV With Freevie
Bundles
Limited Time Offer
See Bundles - Save £75 on LG SH7 360W Soundbar with this TV!
Delivery
Standard Due date unavailable
Experience a fantastic world of entertainment from the comfort of your home with the LG 49LF510V 49-inch TV. Rated A+ for energy efficiency, this HD TV has an ultra slim design with a 49-inch display and a 1920x1080p resolution that projects images with outstanding quality. If this wasn't enough, there is even a built-in Freeview HD tuner that gives you access to a wide range of TV channels with the addition of an electronic programme guide so you can keep on top of your week's viewing schedule.Offering a number of connectivity options, the LG 49LF510V 49-inch TV comes with a single HDMI connection and supports USB connectivity for the playback of compatible content on the 49-inch Full HD display.
Interfaces/Ports
Total HDMI Connections
Total Scart Sockets
Total USB Ports
HDMI Standard
CI Slot
Component Input
Ethernet Port
Headphone Socket
Memory Card Slot
PC Input
Built-in Devices
Freeview HD
Energy Performance
Energy Effiency Class
Power Consumption - Average
Screen Size
Energy Consumption (Annual)
Energy Consumption (On Mode)
Power Consumption - Standby
Dimentions
Viewing Angle (°)
Vesa Size (mm)
Height With Tabletop Stand (cm)
Height Without Tabletop Stand (cm)
Weight With Tabletop Stand (kg)
Product Height
Product Width
Product Depth
Product Weight
Assembled Height
Assembled Width
Assembled Depth
Sounds
Total Audio Power Output (Watts RMS)
Digital Audio Output
Audio Processing
Display and Graphics
Maximum Resolution
Contrast Ratio
Screen Type
HD Ready / Full HD / Ultra HD
Sleep Timer
Wall-mountable
DLNA Complaint
Miracast
Tuner
Smart / Internet TV
Wi-Fi Enabled
Webcam
Full Web Browsing Capabilities
WiDi
Interfaces/Ports
1
Total Scart Sockets
1
Total USB Ports
1
HDMI Standard
1
CI Slot
Y
Component Input
Y
Ethernet Port
N
Headphone Socket
N
Memory Card Slot
N
PC Input
HDMI
Built-in Devices
Freeview HD
Energy Performance
A+
43
Screen Size
49"
66kWh/Annum
45W
0.3
Dimentions
Viewing Angle (°)
178 Degrees
Vesa Size (mm)
300 x 300mm
69.5
65.7
4.7
4.5
Product Height
69.5cm
Product Width
110.8cm
Product Depth
20.87cm
Product Weight
4.7kg
Assembled Height
695mm
Assembled Width
1108mm
Assembled Depth
208.7
Sounds
10W
N/A
Audio Processing
Dolby Digital
Maximum Resolution
1920x1080
Contrast Ratio
300PMI
LED TV
Screen Type
Flat
Full HD
Sleep Timer
Y
Wall-mountable
Y
DLNA Complaint
N
Miracast
N
Tuner
Freeview HD
Smart / Internet TV
N
Wi-Fi Enabled
N
Webcam
N
N
WiDi
N
Scroll to top
