BT.com
Wishlist
LG Electronics 49"4K UHD LED TV with Freeview HD 3840 x 2160 Black 2x HDMI
LG Electronics 49"4K UHD LED TV...
£579.28
£579.28
Add to wishlist
Delivery
Standard Due date unavailable
ULTRA HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a new standard of definition.
The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can now enjoy it in incredible detail.
Form follows function with this sturdy and elegant ribbon plate stand.
HDMI 4K can transmit large amounts of data at once. This advanced technology supports 4K video with 60 frames per second, which is the standard for UHD broadcasting. Be ready for the UHD experience for HDMI 4K.
LG 49UF675V 49" LED TV
LED-backlit LCD TV
Diagonal Class
49"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
LAN
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T
Speaker System
2 speakers
Stereo Reception System
MTS
USB
Remote Control
Universal remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
84 W
Energy Consumption per Year
123 kWh
110.4 cm x 5.67 cm x 64.5 cm
14 kg
LED-backlit LCD TV
Energy Class
Class A
84 W
123 kWh
Diagonal Class
49"
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Dimensions
Without stand
110.4 cm
5.67 cm
64.5 cm
14 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Triple XD Engine, Dynamic Color Enhancer, Tru-Ultra HD Engine, TruBlack Control, Dynamic Clear White
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
Digital TV Tuner
Video Features
Teletext
Teletext Memory
2000 pages
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, PCM, AC3, AAC, HE-AAC, E-AC3
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
1
Remote Control
Universal remote
Audio System
Surround Mode
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Optical Sound Sync, Harman/Kardon design
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
Composite video / component video input - rear , Audio line-in - rear , 2 x HDMI - rear , SCART - rear , USB 2.0 - side , Digital audio output (optical) - rear , Network - rear , Serial - rear , Headphones - side
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Panel without stand - 110.4 cm x 5.67 cm x 64.5 cm x 14 kg , Panel with stand - 110.4 cm x 26.1 cm x 70.1 cm x 15.9 kg
Width (Shipping)
119.7 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
79 cm
Weight (Shipping)
19.6 kg
Accessories
LG Electronics 49"4K UHD LED TV with Freeview HD...
£579.28
Essential TV Accessory
£604.27
Scroll to top
