BT.com
Wishlist
LG Electronics 49" LG LED TV with Freeview
LG Electronics 49" LG LED TV with...
Free delivery
£339.99
Free delivery
Price Drop
Was £369.99
44 in stock
£339.99
Add to wishlist
Delivery
Standard 1-3 working days
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
Clear Voice enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice.
Picture Wizard III
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, colour, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
Virtual Surround
More channels, better sound. High quality software creates a surround sound effect producing virtual audio channels. Surround your senses with sound from all angles.
LG 49LH5100 49" LED TV
LED-backlit LCD TV
Diagonal Class
49"
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
50 Hz Refresh Rate
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T
Speaker System
2 speakers
Sound Effects
Virtual Surround Plus
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A++
Power Consumption (On mode)
39 W
Energy Consumption per Year
56.94 kWh
110.8 cm x 8.15 cm x 65.7 cm
10.6 kg
LED-backlit LCD TV
Energy Class
Class A++
39 W
56.94 kWh
Diagonal Class
49"
Video Interface
HDMI Ports Qty
1 ports
Dimensions
Without stand
110.8 cm
8.15 cm
65.7 cm
10.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
50 Hz Refresh Rate
24p Technology
24p Real Cinema
Canal Ready, Triple XD Engine, Noise Reduction
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
DivX
Supported Audio Formats
MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2, RA
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Surround Mode
Sound Effects
Speaker System
2 speakers
Clear Voice technology
Speakers
2 x main channel speaker - built-in
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
HDMI , USB 2.0 , SCART , Composite video input , Component video input , Audio line-in , Network , Serial
CEC, IEC 62087 Edition 2
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
Panel without stand - 110.8 cm x 8.15 cm x 65.7 cm x 10.6 kg , Panel with stand - 110.8 cm x 20.87 cm x 69.6 cm x 10.9 kg
Accessories
LG Electronics 49
£339.99
Essential TV Accessory
£364.98
Scroll to top
