BT.com
Wishlist
LG Electronics 47WX50MF 47" 1920x1080 DVI HDMI LED Large Format Display
LG Electronics 47WX50MF 47"...
£2,648.88
£2,648.88
Add to wishlist
Delivery
Standard Due date unavailable
The Ultimate Visibility Enhancement!
Key Features:
  • LED (PD Panel).
  • High Brightness : 2,000nit.
  • Shine-Out.
  • Easy Customization (Open Frame).
LG 47WX50MF FLATRON - 47" LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Silver
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080p
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
PC Interface
VGA (HD-15), DisplayPort
HDCP Compatible
S-IPS
Image Aspect Ratio
16:9
TV Tuner
No tuner
USB
Remote Control
Standard remote
Voltage
AC 120/230 V ( 47 - 63 Hz )
310 Watt
107.08 cm x 15.7 cm x 66.55 cm
23.9 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
310 Watt
Diagonal Class
47"
Commercial Use
Series
FLATRON
TV Tuner
No tuner
Sensors
Brightness sensor
Video Interface
PC Interface
HDCP Compatible
225
Dimensions
Without stand
107.08 cm
15.7 cm
66.55 cm
23.9 kg
Enclosure Colour
Silver
Display
LCD Display Technology
S-IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Hard
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1500:1
Brightness
2000 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.761 x 0.761mm
Response Time
9 ms
Backlight Life
50,000 hour(s)
Colour Temperature Control
Digital daisy chain, Shine-Out
Video Features
Input Video Formats
1080p
Media Player
USB Port
Remote Control
Standard remote
Connector Type
VGA input , Serial input , HDMI , Component video / composite video / VGA input , USB , Component video / composite video / VGA output , DisplayPort input , Network , Serial output , Audio input , DVI-D output
VGA cable
FCC Class B certified, UL, cUL, DDC-2B, CB, RoHS, KCC
ENERGY STAR Version
5.1
Power supply
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
Limited warranty - 3 years , Limited warranty - backlight - pick-up and return
Width (Shipping)
118.2 cm
Depth (Shipping)
26.9 cm
Height (Shipping)
74.3 cm
10 - 80%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
