BT.com
Wishlist
LG Electronics 47WV50MS 47" 1920x1080 DVI HDMI LED Large Format Display
LG Electronics 47WV50MS 47"...
£705.88
£705.88
Add to wishlist
Delivery
Standard Due date unavailable
Slimmer Bezel
4.9mm, the slimmest bezels create powerful and impactful video walls.
High Picture Quality
Clear & Vivid picture with deeper black - World Best Dynamic CR (500,000 : 1).
Auto Calibration
WV Series provide Automatic Calibration solution which enables to save time and labour on installation by adjusting the white balance on video wall easily.
Auto Higher Resolution
WV50 supports Full HD. You can enjoy super fine image from each and every displays composing videowall.
Wide Viewing Angle
Providing clear image virtually at any angle.
No Blackening Defect
No need of IR blocker or extra cooling system. Flexibly usable in various signage environment.
True Colour (IPS)
LG IPS technology provides true vivid color than conventional display.
LG 47WV50MS 47" LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
160 Watt
104.49 cm x 8.99 cm x 59 cm
18.7 kg
160 Watt
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
104.49 cm
8.99 cm
59 cm
18.7 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
800 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Certified for 24/7 Continuous Operation, compatible with SuperSign Software
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
Component video / RGB input , Composite video input , HDMI input , Serial input , USB , VGA output , Network , Serial output , DVI-D input , DVI-D output , DisplayPort input , Audio line-in
Power supply
Power Consumption Stand by
0.7 Watt
Smart energy saving
Width (Shipping)
118 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
77 cm
Weight (Shipping)
23.7 kg
10 - 90%
Accessories
£7.63
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.84
£41.94
£56.80
Scroll to top
