BT.com
Wishlist
LG Electronics 47WV50BR 47" 1920x1080 12ms DVI-D DP LED LFD
LG Electronics 47WV50BR 47"...
£1,800.34
£1,800.34
Add to wishlist
Delivery
Standard Due date unavailable
Display has a built-in temperature control that adjusts to light and heat eliminating dark or blackened areas.
WV Series provide Automatic Calibration solution which enables to save time and labor on installation by adjusting the white balance on video wall easily.
WV50 supports Full HD. You can enjoy super fine image from each and every displays composing video wall.
LG 47WV50BR 47" LED display
LED-backlit LCD flat panel display
150 Watt
Diagonal Class
47"
Commercial Use
Yes - digital signage
104.5 cm x 9 cm x 59 cm
18.5 kg
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB Port
Yes , 1 ports
Remote Control
Standard remote
AC 120/230 V ( 50/60 Hz )
Environmental Standards
ENERGY STAR Qualified
150 Watt
Diagonal Class
47"
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
225
Dimensions
Without stand
104.5 cm
9 cm
59 cm
18.5 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Dynamic Contrast Ratio
500000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
10 ms
Backlight Life
50,000 hour(s)
Image Sticking Minimization (ISM)
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
Yes , 1 ports
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice II technology
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI input - rear , DVI-Digital - rear , DisplayPort input - rear , Component video input - rear , Composite video input - rear , Audio line-in - rear , RGB input - rear , Audio line-in - rear , Serial input - rear , Remote control - rear , USB - rear , DVI-D output - rear , RGB output - rear , Speakers output - rear , Serial output - rear
IR receiver
VGA cable
FCC Class B certified, UL, TUV, cUL, CB, KCC, KC, ERP
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Smart energy saving
Width (Shipping)
118 cm
Depth (Shipping)
16.5 cm
Height (Shipping)
77 cm
Weight (Shipping)
23.5 kg
10 - 80%
Accessories
£9.99
£5.98
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.99
£39.99
£54.98
Scroll to top
