BT.com
Wishlist
LG Electronics 47WL30 47" 1920x1080 9ms DVI-D HDMI DP LED LFD
Delivery
Standard Due date unavailable
Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced.
With narrower bezel and slimmer depth than those of competitors, you can save space more efficiently with WL30.
LG 47WL30MS WL30MS Series - 47" LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080p
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
Voltage
100 Watt
107.5 cm x 8.45 cm x 62.48 cm
12.3 kg
Environmental Standards
ENERGY STAR Qualified
100 Watt
Diagonal Class
47"
Commercial Use
Series
WL30MS Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
107.5 cm
8.45 cm
62.48 cm
12.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
9 ms
Image Sticking Minimization (ISM)
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
1080p
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
HDMI , USB , Network , DisplayPort input , DVI-D input , DVI-D output , Component video / RGB input , Audio line-in , Serial input , Speakers output , Remote control input
FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.7 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 107.5 cm x 8.45 cm x 62.48 cm x 12.3 kg , Panel with stand - 107.5 cm x 26.39 cm x 69.31 cm x 13.75 kg , Panel with stand and speakers - 107.5 cm x 26.39 cm x 69.31 cm x 14.5 kg
Accessories
£9.99
£5.41
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.68
£40.09
£54.31
Scroll to top
