BT.com
Wishlist
LG Electronics 47LS33A 47" 1920x1080 9ms HDMI RGB LED Large Format Display
Delivery
Standard Due date unavailable
Want limitless entertainment access to movies, shows and apps from the Internet, straight to your TV without a computer? With LG Smart TV access you can. Or you could view sports and fast action like you were actually there, in stunning detail? With its Full HD, you can have that too.
LG 47LS33A-5D 47" Class (46.96" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
47"
Diagonal Size
46.96 in
Commercial Use
Yes - digital signage
Titanium metallic
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
Power Consumption (On mode)
73 W
Energy Consumption per Year
107 kWh
107 cm x 5.56 cm x 62.1 cm
12.2 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Energy Class
Class A
73 W
107 kWh
Diagonal Class
47"
Diagonal Size
46.96 in
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
107 cm
5.56 cm
62.1 cm
12.2 kg
Enclosure Colour
Titanium metallic
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Balance control, Clear Voice II technology
Connector Type
HDMI input - rear , VGA input - rear , Serial input - side , Network - rear , USB - side , Serial output - side , Speakers output - rear , Audio line-in - rear , Remote control input - rear
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Smart energy saving
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
Dimensions & Weight Details
Panel without stand - 107 cm x 5.56 cm x 62.1 cm x 12.2 kg , Panel with stand - 107 cm x 24.7 cm x 67.5 cm x 12.5 kg , Panel with stand and speakers - 107 cm x 24.7 cm x 67.5 cm x 13.3 kg
Width (Shipping)
115 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
70.9 cm
Weight (Shipping)
15.9 kg
10 - 80%
Accessories
£9.99
£5.41
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£15.68
£39.78
£53.88
Scroll to top
