BT.com
Wishlist
LG Electronics 43" Commercial TV  1920 x 1080  300NIT  HDMI  VGA  RJ45  USB
LG Electronics 43" Commercial TV...
£402.85
£402.85
Add to wishlist
Delivery
Standard Due date unavailable
Welcome visitors with a warm greeting message on this marvelous screen. The USB Cloning feature allows you to simply copy the TV settings onto all TVs using a USB stick, a process that is fully automated to save time without having to set each TV one by one. Via the TV's RS-232C port, you can remotely control multiple TVs' power and volume settings simultaneously. Also, you can play images and videos from a USB device and record TV programs to it.
LG Commercial Lite 43LX341C 43" LED TV
LED-backlit LCD TV
Diagonal Class
43"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, HDMI, SCART
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15), Mobile High-Definition Link (MHL)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, hotel mode, Multi remote control, Lock Mode, Self Diagnostics
Settings Cloning Capability
Speaker System
2 speakers
USB
2 ports
Voltage
Energy Class
Class A+
104 Watt
Power Consumption (On mode)
51 W
Energy Consumption per Year
74 kWh
97.3 cm x 32.5 cm x 62.4 cm
13.6 kg
LED-backlit LCD TV
Energy Class
Class A+
104 Watt
51 W
74 kWh
Diagonal Class
43"
Commercial Use
TV Tuner
Sensors
Intelligent sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Dimensions
With stand
97.3 cm
32.5 cm
62.4 cm
13.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Commercial Features
One Channel Map, security lock slot (cable lock sold separately), USB Cloning, RJP Compatible
Stands & Mounts
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
Video Features
Analogue Video Input Signals
PAL, SECAM
Media Player
USB Port
USB Ports Qty
2
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
MHL/HDMI input - side , HDMI input - rear , USB 2.0 - side , RGB input - rear , Digital audio output (optical) - rear , Component video input - rear , Network - rear , Serial input - rear , Headphones - side , Speakers output - rear , Audio line-in - rear , SCART - rear
CB, RoHS, CEC, ERP, EU Ecolabel, CU-TR
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Auto On/Off
Smart energy saving
Scroll to top
