BT.com
Wishlist
LG Electronics 43" 43LH604V Full HD Premium Stand Design
LG Electronics 43" 43LH604V Full HD...
£366.96
More than 50 in stock
£366.96
Add to wishlist
Delivery
Standard 1-3 working days
Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
LG 43LH604V LH604V Series - 43" LED TV
LED-backlit LCD TV - Smart TV
Diagonal Class
43"
Platform
webOS 3.0
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
900 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Picture Enhancements
ColourPrime
Speaker System
2 speakers
Sound Effects
Virtual Surround Plus
USB
2 ports
Remote Control
Standard remote
Voltage
Energy Class
Class A++
Power Consumption (On mode)
35 W
Energy Consumption per Year
51 kWh
97.4 cm x 7.94 cm x 57.1 cm
9.25 kg
Energy Class
Class A++
35 W
51 kWh
Diagonal Class
43"
Series
LH604V Series
Platform
webOS 3.0
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
ColourPrime
Dimensions
Without stand
97.4 cm
7.94 cm
57.1 cm
9.25 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Time-shift, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Digital TV Service
HbbTV
MPEG Profiles and Levels
MPEG4/MPEG2/HEVC
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Digital Audio Format
DTS-HD digital output
Sound Effects
Speaker System
2 speakers
Output Power / Total
20 Watt
Active noise reduction, Clear Voice III technology
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
Functionality
Digital video playback, WEB browsing
Wi-Fi, LAN
Wi-Fi Protocol
802.11n
DLNA
Connector Type
3 x HDMI , 2 x USB 2.0 , Network , Composite video / component video input , Headphones , Digital audio output (optical)
Directive 2009/125/EC, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, EN 55022:2010, EN 55020:2007+A11:2011, EN 55013:2013, EN 62311:2008, EN 61000-3-2:2014, ETSI EN 301 893 V1.7.1, R&TTE Directive 1999/5/EC, IEC 62087-1:2015, EN 300 328 V1.8.1, EN 60065:2014
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 97.4 cm x 7.94 cm x 57.1 cm x 9.25 kg , Panel with stand - 97.4 cm x 19.9 cm x 62 cm x 9.45 kg
Width (Shipping)
106 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
66 cm
Weight (Shipping)
11.7 kg
Accessories
LG Electronics 43
LG Electronics 43" 43LH604V Full HD Premium Stand...
£366.96
Essential TV Accessory
£391.95
Scroll to top
