Click to visit BT.com
BT.com
Wishlist
LG Electronics 42" LCD TV Full HD 1920 x 1080 50Hz 2 x HDMI USB Input - Bla
Quicklinx: 8557WS00
Mfr#: 42CS460
Essential accessories
INCREDIBLE CLARITY, VIBRANT COLOURS
FULL HD 1080p provides the pinnacle of picture resolution with incredible clarity and vibrant colours. With up to five times the resolution compared to standard definition TVs and twice that of `HD-Ready' TVs, FULL HD 1080p is the only way to enjoy the full potential of Blu-ray and HD gaming.
A TVs motion clarity index (MCI) gives you a comprehensive indicator of its ability to handle fast motion without blurring. LG's expertise here makes good use of detailed backlight scanning, advanced local dimming and a powerful clarity engine to deliver a lifelike, detailed picture every time.
High-Definition Multimedia Interface (HDMI) carries both sound and picture in a single cable from your devices to your high definition TV. Now you can easily connect your games console, satellite box, Blu-ray or Home Cinema System through the two HDMI ports for a true high definition entertainment experience
Connect your digital camera, M-P-3 player or USB stick through the USB port to show off your latest holiday snaps, music collection or High Definition movies for a true multimedia experience.
ECO-FRIENDLY REVOLUTION
LG Intelligent Sensor technology automatically finds the optimal brightness, sharpness, colour and contrast picture settings to enhance the picture quality and reduce power consumption.
Smart Energy Saving technology controls the brightness of the TV to reduce the power consumption and therefore help you save money off your electricity bills. The Screen-Off function even lets you listen to music from the TV whilst the screen is off
LG 42CS460 - 42" LCD TV
LCD TV
Display Format
1080p (FullHD)
Diagonal Size
42"
Diagonal Size (cm)
107 cm
Resolution
1920 x 1080
Video Interface
Component, HDMI, SCART
HDMI Ports Qty
2 port(s)
HDCP Compatible
On-screen menu, Intelligent Sensor, Smart Energy Saving Plus, Simplink, Picture Wizard II, Quick View, Triple XD Engine, progressive scan
Sound Output Mode
Stereo
Speaker System
2 speakers
Built-in Decoders
Dolby MS10
Sound Effects
Infinite Surround
Stereo Reception System
MTS
USB Port
Yes , 1 port(s)
Remote Control
Remote control
AC 120/230 V ( 50/60 Hz )
Energy Class
Class C
120 Watt
102 cm x 26.1 cm x 69.5 cm - with stand
15.1 kg
LCD TV
Energy Class
Class C
120 Watt
Diagonal Size
42"
Diagonal Size (cm)
107 cm
Video Interface
HDMI Ports Qty
2 port(s)
HDCP Compatible
Dimensions
With stand
102 cm
26.1 cm
69.5 cm
15.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (FullHD)
Widescreen Modes
Zoom 14:9, Conventional 4:3, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
TV Tuner
Conditional Access
Common Interface (CI) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
Digital TV Service
FREEVIEW
Video Features
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, PCM, AC3, AAC, E-AC3
Supported Pictures Formats
JPG
USB Port
Yes , 1 port(s)
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Digital Audio Format
Dolby Digital output
Built-in Decoders
Dolby MS10
Surround Mode
Sound Effects
Infinite Surround
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
10 Watt
Clear Voice II technology
Speaker(s)
2 x main channel speaker - built-in - 5 Watt
Connector Type
2 x HDMI input ( 19 pin HDMI Type A ) - rear , 1 x USB 2.0 ( 4 PIN USB Type A ) - side , 1 x component video input ( RCA phono x 3 ) - rear , 1 x audio line-in ( RCA phono x 2 ) - rear , 1 x SCART ( 21 PIN SCART ) - rear
Expansion Slots
1 x Common Interface slot
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
200 x 200 mm
RoHS
Power supply - internal
Nominal Voltage
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
Panel without stand - 102 cm x 26.1 cm x 69.5 cm x 15.1 kg , Panel with stand - 102 cm x 7.7 cm x 62.9 cm x 13.5 kg
